My car has been sitting for about 3 years. I finally installed the 60# injectors, TT chip, fuel pump, cleaned out all
fuel lines & gas tank, replaced the fuel filter. Car was running pretty good. Then drove is without getting into the boost to work to change the oil.
After the oil change there is white smoke coming out the exhaust when
the car is started and idles. When I drive the car the smoke is gone and when sitting at stop lights there is no smoke. I checked the oil level. Checked for coolant in the oil. I am stumped.
I also just hooked up the scan master and the O2 are anywhere from the
300's to the 600's at idle. Is that normal?
