snap on distributorless ignition tester.
chris718
test the output of the coilpack into the plug wire,great for turbo buicks.30.00.quickly finds bad coil or plug/wire.self powered.
is this for any coils or just for a gm plug of that year or is it good for any other interchangable coils?
it is used for testing gm dis ignition systems like that on turbo regal.it snaps over plug wire and reads voltag.it came out in the late 80s so you could tell iff you had a bad coil.also works on the gm stuff with seperate coils like the 3.1 lumina etc.
W
ive also got a snap on axle spindle thread repair tool new,matco disc brake four piece caliper tool kit for rotating calipers back in on disk brake caes,astro ac clutch compressor remove and reinstall kit,gear wrench serpentine belt ratcheting tool kit .
