so i got back from prescott late last night. i went up there to work on the gn.
we got some things done but were stuck on some others, there seemed to be some missing parts. ill be able to get back up there again in a few weeks. hopefully this is all thats left to do;
run air lines for the air springs
install the trans cooling lines
put on trans filter/ gasket and fill with fluid
torque converter bolts/ inspection cover
install starter
find ans install the shifter linkage
bleed brakes
hook up fuel pump hotwire kit
install dual fans/ relays
screw in fan switch
fill rad with h20/ anti freeze
torque strap
slide 3" thdp in
bolt on cat and 3" exhaust
finish the dutt neck and install intercooler/ piping
set cam sensor
change chip to 009 street chip
fill engine with oil
bolt on hood
bolt on front air dams
trunk x braces
put it front triangle braces and fender braces
im thinking thats all except for one thing, i need to figure out the boost soleniod and lines; can someone email me some pics of how all of this hooks up as well as some good pics on complete engines? its been 3 years since i took it apart and its a little hard to remember where everything goes
thx
buickbert
install starter
bleed brakes
screw in fan switch
torque strap
slide 3" thdp in
set cam sensor
bolt on hood
trunk x braces
thx
buickbert
