outatime86
 - Aug 14, 2018
Wanted to give a big thank you to all who have helped me out this past year in getting my car back running.  It's been 18 years since on the road.  Here are the updates.
Small list of what's left to do. Rear wheel cylinders, install and modify dual 3" cat back it's a pypes system but will change to flowmaster single chamber mufflers, install trans cooler, and have Norbs do my tuning FAST B2B. New alky kit bought but to be installed once running okay.
Things done; had to pull and rebuild the trans with billet servo and new clutches n steels n hardened steel input shaft. Installed all new rear suspension - hotchkis adj uppers, solid lowers, braces from lower to uppers, 1.5" solid rear sway bar. Dropped fuel tank changed the sock on the 340 hot wired pump, installed 120lb low impedance injectors, new fuel filter. All new shock bushings for my rancho rs9000. New hotchkis front sway bar. Custom Garrett core FMIC, built my own 3" piping. New tires front 225 16 and 275 16 drag radials on custom made 16" riken wheels, 16x8 and 16x9.5. New rubber body bushings installed. New wildwood brakes up front. New hydroboost system. 4" home custom made intake to feed the t66 dbb. Old converter 3600 nlu still works good. 3.5" dented for clearance DP. Fbody radiator for purging n flushing all the shit out, will reinstall becool once crap is flushed out.
Thank you to all who have answered my calls for help and questions. The build is in dedication to my pops who passed last year.
