Usually if they blow only when the motor/pump is running intermittantly it's the motor/pump drawing too much current and needs replacing.
If the motor runs too long due to a bad accumulator and only blows the fuse after 30-40 seconds of run time you may get away with a new accumulator so the pump doesn't run as long. Depends on the symptoms.
If they blow as soon as you insert them it's probably the wiring shorted but that's rare.
I got some 35A fuses online that work out okay in the GN that blew a couple of fuses in the winter when the motor/pump takes more current to work.
Never had a problem in the warm weather.
It's not the best solution and you need to make sure the wiring is in good shape as fuses protect the wires in the car.
Some have gone to 40A fuses also, more readily available, but again it's a quick fix not a long term solution, and you could fry some wires if the pump starts to draw too much current etc.
Finding a good used or new motor/pump isn't all that easy either.
