G
GNJeremy
Guest
OK, I just had a new TA49 turbo, V4, and 009's put on my car.
Now I am having all sorts of problems. Off the line it has absolutely nothing all the way through first gear. It gets maybe 7psi, and thats it. In second, it creeps up to about 10, and in third, it shoots up to 22-25 psi and runs fine.
fuel pressure is set at 47psi line off. The scanmaster shows like 870s in first and second, gradually dropping off to 790s by third, and around 90-100 I start to see 2-3 knock. (i let off here)
Here is a list off my mods:
TA49 w/ ported elbow, and 1.25" wastegate hole
V4
009's
Hooker exhaust (yes the headers too)
AFPR
caspers ultrachip burned for my combo
poston's 3" DP
adj wastegate
no cat
new O2
New valve springs
K&N 9" filter
lots of little things
I run 116 leaded
V4
009's
AFPR
poston's 3" DP
adj wastegate
no cat
new O2
New valve springs
K&N 9" filter
I run 116 leaded
