hot air 84GN
- May 7, 2009
I know its redundant, but whats the correct way to set the cam sensor? After disconnecting the orange wire or battery terminal. And after you find 25 deg ATDC, using a piece of tape 1.45 inches. When the cam sensor is losened, do you have to turn it clockwise before turning it counterclockwise? The electronic tool says turn it 1/4 turn clockwise before turning it counterclockwise. The sticky at the top of the forum doesn't mention turning it clockwise at all. The voltage has to go from a higher measured value to a lower value to know the voltage is dropped. I have read the procedure lots of times but every post is different. Also, you can cheat when you get it close, cant you? Just by moving it very little to find the sweet spot? Normally how wide is this "window?"
Any thoughts?
Any thoughts?
