I have (2) different set of solid roller lifters now. One is a full body type and the other is the kind that has half the upper part machined away. (I'll try to get some pictures later.)
My questions:
What makes a solid lifter unable to work in a Stage 1 motor? If I keep the lift at the cam moderate, can I use these? What is different about those ballyhooed "shielded foot" lifters that you can supposedly run in a stock block?
Another thing, those stock block compatible lifters... I've read several times that they can only work on cams of less than .500" lift. Is that at the cam or valve? What ratio and who cares? Tell me what the maximum cam lobe lift can be. If I need more lift, I'll use higher ratio lifters.
Thanks,
Roger
My questions:
Thanks,
Roger
