Mar 18, 2007 #1 U Underboost Mr. Dull Joined Oct 4, 2005 Messages 4,277 Can you run a solid roller cam with the stock ecm?
Mar 18, 2007 #2 O Otto J Well-Known Member Joined May 31, 2001 Messages 10,546 Dont see why not,Just need a properly burnt chip to make it run correclty
Mar 19, 2007 #3 750H.P.V6 Brutal 6 Racing Joined Sep 4, 2001 Messages 3,619 I did it worked fine for me. Neal
Mar 19, 2007 #4 N nordy racer Active Member Joined Aug 2, 2004 Messages 3,173 going all out a see Brent. must be nice big dog..
Mar 19, 2007 #5 U Underboost Mr. Dull Joined Oct 4, 2005 Messages 4,277 nordy racer said: going all out a see Brent. must be nice big dog.. Click to expand... I'm just checking. I'll change my gears first.
Mar 19, 2007 #6 N nordy racer Active Member Joined Aug 2, 2004 Messages 3,173 Underboost said: I'm just checking. I'll change my gears first. Click to expand... Sure
Mar 19, 2007 #7 750H.P.V6 Brutal 6 Racing Joined Sep 4, 2001 Messages 3,619 What size cam are you running now? You're running 3.73's with a 28 inch tall tire correct? Neal
Mar 20, 2007 #8 L Lee Thompson New Member Joined May 24, 2001 Messages 3,184 ? Still able to use the factory knock censor??
Mar 20, 2007 #9 750H.P.V6 Brutal 6 Racing Joined Sep 4, 2001 Messages 3,619 It's still screwed onto the block but its not plugged in. Neal
Mar 20, 2007 #10 G Googs I've "GOT BOOST"! Joined Mar 13, 2005 Messages 359 I'm running one right now in my car, with the knock sensor still hooked up also. No problems at all.
