Something weird
mike
I was driving with my Direct Scan on last night and I got on it a little bit. 6 or 7 different codes were popping up, TPS hi and low, 02 sensor, motor not running, forgot the others. Also the first value for my BLM's was 0 and a couple others were 150. So, I shut my DS off and none of this came back after I turned it back on. Could it just be the connector to the computer be bad?
More than likely its just the connection between the cable and ecm is a little off. Its been documented as a troublesome connection to get perfectly clean and not pushed on too far which can do funny things like that.
