I finally got the HG's installed, and the engine back in today after blowing up both my HG's a couple of weeks ago...see
http://www.turbobuick.com/forums/engine-tech/252588-ahh-head-gaskets-oil-bath.html
Anyhow, took the car out but did not attach the wastegate rod because I didn't want to run any boost just yet until I get a couple of warmup cycles. On engine alone, the car ran hard. Finally this crazy problem of the car dying when I go to WOT has gone away..or so I thought o when I put the wastegate rod on. When I start making boost the engine just lays down when I try a WOT. This got me to thinking, and I certainly would like other opinions, I'm thinking that I'm getting a spark blowout condition. Reason why is when the engine lays down, it almost acts like I could pedal the throttle to bring it back, but it ultimitely dies and backfires...like gas that's in the combustion chamber that never got lit. If I put the car in neutral, it will start fairly easily. Now without any boost, ran fine at WOT no hickups at all, but under boost pressure I think it's knocking it out. Edit...I should mention that no codes come up.
I ohm'd the coils, they check good, but they also have a original 87 date code..could they possibly be faulty under boost? Or could it be the ignition module? I have some ngk's gapped at 32, and before that, some ac delco's so I'm certain plugs are not the issue.
On another note, wouldn't you know after all this testing the dreaded "hard pedal" reared it's ugly head....geesh I can't catch a break. I noticed I had a bunch of brake fluid under the car, and it was coming from the PM motor area. I have taken it off and upon further inspection, the end seal just has a bunch of crud caked on it after I tore it down. I'm off to the store to get some brake fluid and cleaner so I can clean this up. I think it's salvegable
 just need to clean all the junk that accumilated in it.
Steve
Walboro fuel pump w/hotwire, 3" DP w/testpipe, 009 injectors w/ TT chip, BM shorty cold air kit w/9"KN Filter
Steve
