Car was running great the past couple of weeks and i even got it on the dyno. Then a few days after i started to get spark knock intermittently, but it was a sound i haven't heard before. Sometimes it would do it under wot and sometimes it wouldn't and then it get worse and done it all the time at wot. I decided to pull the plugs and some of them have a red residue and the number 6 plug porcelain was spinning inside the metal nut. You could actually turn the porcelain while holding the nut. Im guessing this was the cause of the spark knock, i was wondering if anybody else has had the same problem with the spinning plug. The plugs ar autolites 24.
