Ok, does the engine crank over or not at all?
I have never heard of a car not starting because of a bad MAF?
Are you getting spark? Take a spare plug and put it in a spark plug wire and crank the engine over and take a look.
Sounds like your running rich problem is the MAF. Unless you currently have an exhaust leak before the O2 sensor? That will cause the O2 sensor to throw more fuel at the engine. Then you will foul your plugs in no time. You need to change those passenger plugs once you get it running!
How did Eric burn your chip? Was it burnt for 30# injectors, 87 ECM and a 87 MAF or the stock 85 MAF? Check your connections by the ECM too. What is your fuel pressure at? Does the car run better if you drop the fuel pressure?
Another thing is that it is the middle of winter, maybe your fuel system is frozen? That will cause the engine to just crank over and not start. Is you gas tank over half full?
-Nick
