FatNasty231
- Sep 12, 2005
just wanted to get a few members' advice on what would be the best spark plug to run in my '87 GN. i will also be running MSD wires with them.
SignUp Now!If the car is stock to lightly modified run AC R43TS gapped at a tight .035". For a higher performance level use an AC R42TS gapped at .032". Autolite plugs work well too. It's personal prefference at that point.
Neal
I'm just clutching at straws. I was troubleshooting a WOT surge/lean misfire, and cured it with a ign.module/coil pack swap, but also added new plugs gapped at around .028-.029.
But all of a sudden a new problem has arose. Now, after startup and during warm up, the idle quality is horrible and the A/F ratio is all over the board from 10. up to 17.![]()
Also notice while driving if I really really slowly tip into the throttle it goes quite lean, about 17:1
This doesn't happen if I tip in even just a little quicker than normal.
Have you had a guage to check fuel pressure, is the fuel system up to par?? (i.e.pump, tank, filter) I had a similar problem, and I had to replace the fuel tank, because after a few minutes of driving the fuel sock would get contaminated with rust particles. I put in a new tank and everything it cool now. What other info can you give us??
