Is all pieces excluding the spare tire cover straight up and down?
>Yes, but the trunk pan that the amp rack sits on is not level so the amp rack is deeper in the front than the back. I used a square to make sure the box was at a 90 degree angle to the subbox.
Is the spare tire still there?
>yep
Is the material used press wood or did you just do the box itself and use something else on the other panels?
>Everything is MDF (medium density fiberboard) Box is 3/4 everything else is is a mix of 1/2 and 3/4 inch board.
Which piece did you install first and last?
>Amprack first. then the box. then the sides.
Is there dyna mat installed?
>Yes. Floor, sides and the filler strip bettwen the backglass and the trunklid. Still need to do the trunklid.
how does it sound?
>I sounds good, could be better. I think I liked it better when I had them firing forward. I rearfired them cause I wanted to show them off (for shows) Still sounds good with rap/hip hop. But considering I listen mostly to older rock n' roll (Eagles, Lynard Skynard, Doors) it's not the best for me.
Looks cool though
I'm planning on redoing it with a single 12" and lose at least one amp. It's total overkill but I had all the equipment so I threw it in!
