SignUp Now!How do you know it's advanced 4*? It will pull to 5700 with 30psi boost if the combo is correct. I've run a similar intake lobe and had it advanced 2 or more degrees every time. Once I had it advanced almost 6*. The least powerful of the 4 engines of mine I've used a similar intake lobe it propelled the car to 127+mph in the quarter. There was not one point in any of the quarter mile that any of those engines were below 5000rpm from the instant the engine got over 5000. Flash stall was about 5000rpm on the least powerful oneBison, if this cam were advanced 4 degrees, would you happen to know if it would still pull to 5000 rpm?
Looks like the advance was ground into it. Id install it and adjust it to the intake centerline they use on the cam card. If you have a decent flowing set of heads a higher rocker ratio will help. A te60 is about the same as a te44 on spoolup. It's a mismatch of wheels though. The turbine won't flow as much as te 60-1 compressor. It falls about 100hp shy at the same pressure ratio around 5000rpm. This is assuming you are running it for all it's worth with the small turbine and comparing it to the p trim run for all it's worth with the same compressor. Actually the p trim turbine will go further than the 60-1 conpressor wheel but it's a much closer match and way more effective if you run alky injection and have good heads. The small turbine te60 will drop off over 4600 from backpressure with good heads. With stock heads it will go a couple hundred rpm further. The cam really needs to be run with the larger p trim turbine to really make it wake up between 4800 and 5300. if you read the thread I made in the time slip section you can see what the 60-1 can do with a p trim and junk heads. Your cam would likely suit the combo I posted better than the 212 I used if it had 1.65 rockers and better heads than I did. It would probably make the same power at 5psi less boost. Fwiw those open/closing numbers on that card are at .050 tapper lift.View attachment 148142
I don't have proof per se, but I did get the cam card with the car that stated said cam was installed 4 degrees advanced. Also I recently swapped from a D5 (that I believe is stock) to a PTC 2800 LU converter and didn't see much improvement short of a .20 quicker 60 ft. (foot brake launching on 5-10 psi) and spool up is a little quicker now. My car pulls well from idle to about 4500. I figured the advancement of the cam is what's giving me the strong low to midrange power, and perhaps even allowed the use of a TE60, as I have read they're really laggy behind a D5.
Here's the cam card I received, perhaps there's something you could see/point out?
Thanks in advance.
Hey Bison, this cam is actually already installed on my car. My engine has stock heads, I don't know if they've been ported or not.
Now are you saying on my turbo it has mismatched wheels?Should I swap them out?
Running it for all its worth....well when i race I do floor the accelerator and I have the psi set in the 23-25 range, not sure if that's all it's worth or not.
Now I gotta ask what's the p trim you speak of? Is this the turbo housing? Should I swap this out?
Also I've noticed on my car about 4600 it begins to feel like the power tapers off, that's why I thought an advancement of cam would do this, however you said this is where the cam tapers off on aftermarkets but it will be a few hundred rpm higher on stockers.
Thanks in advance, your posts have been helpful. :smile:
I'll send you a pm later with 3 key components that will really allow you to extract a lot of power with that compressor. You will need a ptc 9.5" to couple the power potential. The 60-1 flows the highest mass flow around 25-26psi. Around 60 lbs/min. Most don't or didn't have enough engine to max it out at that pressure ratio (including me). so I opted to overspeed the compressor to get the performance I did with it. As a result i probably choked of about 3-4lbs/min of airflow but if you crunch the numbers that's about 590-600hp. The car trapped 127.85mph. Looks like it's right where it should be.Hey Bison, this cam is actually already installed on my car. My engine has stock heads, I don't know if they've been ported or not.
I wouldn't mind a forward on that. I was really impressed with the otto thread where you guys made pulls with different turbos. I remember you made very good power with that 6169I'll send you a pm later with 3 key components that will really allow you to extract a lot of power with that compressor. You will need a ptc 9.5" to couple the power potential. The 60-1 flows the highest mass flow around 25-26psi. Around 60 lbs/min. Most don't or didn't have enough engine to max it out at that pressure ratio (including me). so I opted to overspeed the compressor to get the performance I did with it. As a result i probably choked of about 3-4lbs/min of airflow but if you crunch the numbers that's about 590-600hp. The car trapped 127.85mph. Looks like it's right where it should be.
I'd use comp 941 or k motion 750 and install with around 135-140 seat pressure
