- Feb 14, 2002
Or any other application for that matter....You cant take any action against Spectre .. that aircleaner should have never been used in your application .. period
SignUp Now!Or any other application for that matter....You cant take any action against Spectre .. that aircleaner should have never been used in your application .. period
Why is that? Just because it is cheap or is it not meant for boosted motors?You cant take any action against Spectre .. that aircleaner should have never been used in your application .. period
If that was the case they would be required to state such a fact on the box to limit there liability. No where on the box does it state it is not intended for a boosted application.
That's not the point. That same air filter could've damaged any number of makes and models of vehicle, it's a stupid design flaw that caused this mess...not the application.You cant take any action against Spectre .. that aircleaner should have never been used in your application .. period
EDIT, I just noticed that he has a pro speed density MAFT.How did that button get passed the honnycomb screen in the mass air flow sensor?
.................Chuck. I should contact the parts store? I'm almost positive this isn't going to get solved without a lawyer. I'm not positive I have a receipt for this filter.
Not so .. The design might work in every NA application and fail in a boosted one just based on flow characteristics.That's not the point. That same air filter could've damaged any number of makes and models of vehicle, it's a stupid design flaw that caused this mess...not the application.
