J
JoshSosnin
Guest
Hello all,
A friend let me know that this forum has some Speed Pro owners. Looks like a nice forum...
Anyways, I own a dyno in PA and had someone stop in with a Speed Pro the other day. He was not quite up to speed (laugh, sorry) with the unit, so I started to play with it. His poor car was off the chart rich, and picked up almost 100hp with some quick fuel and timing adjustments.
Comments: Not a bad unit, seems to work well. The interface is perhaps so-so, but if someone could go from never seeing the unit to picking up 100hp (no boost changes) in one hour, it must work, right?
Questions: How do I change the trigger for the data logging? For some reason, the unit would never see above 60% TPS, so the data logging would not start.
Does the unit record knock? Anything at all with recording timing advance?
Location of a FAQ perhaps?
Thanks so much for your help!
Josh
Josh
