SignUp Now!If you take off the cable, the ECM won't know the car's speed, since the speed sensor is built into the speedometer. So no, the Cruise won't work, and your torque converter lockup won't either, unless you have a manual switch. You'll get a trouble code, and your mileage may suffer a tad. Other than that, it really won't hurt anything.alphaenvirmgt said:...If I take the cable off the car will the cruise control still work? Anything else affected?...
alphaenvirmgt said:Does the speedometer cable do anything other than drive the speedometer? If I take the cable off the car will the cruise control still work? Anything else affected?
Conrad
Incorrect. The speed sensor is in the speedometer itself. The older cars had it under the hood. Casper's Electronics probably has what you need in order to eliminate it.bruce said:The cruise works off of the box under the hood where there's a speedo cable going in, and one coming out.
If you want to eliminate the upper cable that goes to the speedo head, then you need to install a *2* shutter, inline speedo sensor, and feed it's signal to the ecm (you'll probably have to do some more digging for the finite details about the wiring). www.jagsthatrun.com used to have the sensors.
pacecarta said:bruce, for the 86-87 the speedo cable is two peice but it doesnot have any pysical connection to the cruise servo as it did in earlier GMs, the cruise servo is electronic , if you loose the VSS signal and the servo has no reference to maintain speed
for the aftermarket speedos to work and maintain VSS they need to have a VSS sender installed in the speed cable (usually where the two cables join by the mastercylinder )
pacecarta said:what you said was that theres speedo cables connected to the cruise or a box of some sort .
