hey guys,
having some problems with fuel calc and map sensor. I have a 90 Pontiac Grand Prix Map sensor (I assume to be a 1 BAR - what I need), I also have a 3 BAR map. I used the 3 BAR just to start up, I see the 0-100, 100-200 and 200-300 kpa no problem, at no vaccum she reads the 100kpa number at whatever rpm. I plug in the 1 BAR GM sensor and the values stay at 0-300kpa but the values that are beign used ar the 300kpa with no vaccum, is this normal ?
another problem:
I have a friends program whose setup is very similar to mine. I could not use his fuel table because there is not enough fuel for my setup (I set my reg to his fuel pressure and I have his injector size and displacement input into calc). I need to change a few of my values from 32 to something like 70-73 in order for this thing to idle ... I went to the fuel calc table and reinput and the numbers on the fuel table dont seem to change, is there somehting I need to do in order to recalc a new fuel table after inputting all of the variables, i.e. injectors, displacement and num of cyls ? ?
I didn;t want to have to build a whole new curve but was hoping to use his entire set of tables for my setup until I hit the dyno. The car will idle for a little then die, I have ot redo the entire map. I'm positive about his injector size and fuel pressure Any help ?
thanks,
Greg.
another problem:
thanks,
Greg.
