This thread won't be completed for awhile but I figured if 11 of you bought a spoiler maybe a reference would be good. I will give Jared (72firebird) and Jan (Jan Larsson) credit for how I plan on installing it.
To start you need to remove the old spoiler. There are four bolts you need to remove from the underside of the hatch. One in each corner of the spoiler and two in the middle where the 3rd brake light is. These are all 10MM. You will need a ratchet as the bolts on the corners are in there TIGHT.
You will need to pop the little plastic covers off with a screw driver or flat bladed scraper.
Then the middle ones.
And the right one.
The far left one on my car would not come out. There is a metal nut inside the rubber compund and what happened was the rubber was so detiorated that is wouldn't grip the nut anymore. So it just turned. More on this later.
To remove the spoiler you push the corner toward the front of the car to remove it from the little plastics clips that hold it in. Do not worry about breaking these off as you will not need them. Just hit the spoiler forward and lift it straight off. It will move about 1/2" to an inch. This worked for the right side. If you happen to have a screw that is stripped like I did you will have to lift up the spoiler off the screw and hit it forward. The rubber is pretty pliable and it didn't even crack. I didn't care if it did anyway but for those of you who want to keep it, just be careful. Once you get the spoiler off you will have to tilt it towards the ceiling to remove the lighting fixture. There are two more 10MM sockets that you remove for the third brake light as seen here. I was able to remove these without a ratchet and just a socket on a screwdriver deal. (sorry my terms are off I haven't had to think in over 14 days :wall: )
Be careful not to rip these wires out....
You should have seen the dirt and grime under the spoiler. I spent about an hour with an orbital polisher and a fine cut polish to remove the yellow tint. I can't get it all but I will continue with it.
Board says I need to split.......
And the right one.
