Spoiler mount studs pulled out.
rtviper
Has anyone tried to put the spoiler studs back in their original holes with success? What did you secure then studs with so they would allow the nut to be srewed on again.
I don't have a factory spoiler but if the studs are threaded in and the threads have pulled out you should be albe to use an epoxy to glue tham back in.
same happened to my header panel.I Used 2 part epoxy steel from home depot,stud is stuck like glue.
Forgot to add,make sure you wire wheel the threads on the stud,probably had rust on it and the reason it pulled the stud out of the spoiler.
