I am starting work on my high mileage car that is new to me. I pulled the intercooler last night and cleaned some oil out of it. Up pipe had oil in it. Then I decided to clean the throttle body which led me into removing the upper plenum. I find the egr passage blocked with carbon and generally oily lower intake. Would it be worth my te to pull it and clean the oily residue out and clear the egr passage?
If I pull it should I do anything to it since it will be off?
Car has #36 injectors 3"down pipe 2.5" exhaust aftermarket up pipe and pipe coming from MAF.
Brandon
Brandon
