Spring for column shifter & hard top roof weatherstrip OEM GM
dwall
  1. The spring is located/needed for the column shifter. It sits right under the base of the shifter handle right below the opening to the steering column. Another mystery part disappearance - AAArgh.
  2. Also I need a set of roof to window OEM GM weatherstrips. I imagine they are getting hard to find.
That's all for now - LMK if you might part with either of the above.
Bob
