Dlynch1130
1986 Buick Regal -$11,000 OBO
Black with light gray interior, chrome exterior trim. Base model with 307 Old v8. 98,000 miles. 2004R four speed transmission and torque converter out of a 140,000 Regal T-Type. Exterior paint is a 7 or 8 on a scale of ten. There is one long scratch on each of the rear quarter panels which are light and only visible in the bright light. The last picture shows the rust at the bottom forward edge of the driver side wheel well. There is light surface rust underneath. Options Includes power windows, manual locks and lighted driver’s side vanity mirror. This Regal originally had front bench seat and column shift. This Regal corners flat, the steering has a nice heavy weighting due to the valve Tom Lee installed in the steering box and goes where you point it.
See below for details of upgrades made. My e-mail address is dlynch@outdrs.net. Car is located in Coral Springs, FL. The purchaser of the car will also have the opportunity to purchase for $300 the complete kit of driver quality black trim (excluding the side marker lights and right rear wheel well trim both available from Highway Stars) and new AFX performance spindles and G Body Steering Arms for $750.
Interior – Converted from Bench Seat/Column Shift to Bucket Seats/Floor Shift
- New headliner
- Recovered sun visors
- New carpet
- New console lower and center sections
- G-Body short shifter and new shift handle
- New turn signal/Speed control stalk
- New speedometer cable
- Used floor shift steering column
- Used T-Type steering wheel
- GN bucket seats installed, recovered with NOS correct gray fabric and new foam rubber
- Seat belt receivers for bucket seats
- Trim Replaced – Replaced woodgrain with gray
- Door panel escutcheons
- Screw covers
- Instrument cluster bezel, radio bezel and glove compartment plaque
- Radio with correct OEM mounting brackets
- WS6 36mm front anti-roll bar, gloss black powder coated, new rubber bushings and gloss black powder coated straps
- F41 rear anti-roll bar w/NOS mounting brackets and bolts to rear lower control arms, gloss black powder coated
- Front and rear Koni Special D adjustable shocks
- Global West front lower control arm bushings
- New AC Delco center link, tie rod ends, bumpers, ball joints, front upper control arm bushings, idler arm, rear control arm bushings
- OEM Front upper and lower control arms media blasted and gloss black powder coated
- OEM Rear upper and lower control arms media blasted and gloss black powder coated
- OEM Braces: Radiator cross braces, core support to fender, front GP cross brace and jounce bars
- Rear frame rail brace
- GNX brace behind rear seat, powder coated gloss black
- Moog 5658 front lowering coil springs, Moog 5413 rear lowering coil springs
- TMR Customs Suspension Limiting Straps
- Lee Manufacturing Series 800 steering box (12.7:1)
- Powersteering.com modified power steering pump and reservoir to provide GPM flow and pressure for Lee Mfg. power steering box
- Metal steering column from a Safari Van, eliminates the rag joint, klunks a bit on certain types of bumps in the road.
- Tires: BFG G-FORCE SPORT COMP-2, front 245/50-16 and rear 255/50-16
- Wheels: Trans Am style, front and rear, 8” x 16”, zero offset, no dimples GM wheels
- New G Body parts steel turbo hood and install kit
- New windshield and plastic trim
- New vinyl roof
- NOS front and rear bumper impact strips
- OEM one piece front spoiler from 1984 GN
- Rick Hunt metal wheel well extensions and patches to allow fitment of wider/taller front tires
- New Big Boar Muffler, tail pipe and mid pipe
