Spring Tune-Up
Spoolin Hooligan
Off the wagon Boost Addict
Ok so I'm doing my first tune up on My car since I bought it in August. And would like to know what works best in our cars plugs wires oil and filters. And should I do anything with the coil pack. Because I have never messed with one. Any suggestions would be appreciated. Hopefully after this I can go to the tuner and be ready for the track in spring.
I usually always change the trans filter, clean the K&N, R34RTS plugs, MSD wires, Purolator Fuel Filter, New rear-end fluid (valvoline 80W90), Brad Penn 10W30, bottle of prolong and K&N oil filter. But I am a tick anal sooo.... :P
You might want to run your gaps on the spark plugs a little tighter than what GNTType says. If you are running 20+ PSI of boost, R43TS @ .028 should work.
haha well im not running 20+ PSI yet going to the shop to try and get 18
Before I added Alky, I went with CR43TS @ .032. Try that. You can always change it.
Nix
Good to hear! Have fun with it! I run the same wires. MSD 8.5 Streetfires I think. I made them myself with a cheap vice and the tool they give you.
