squeaking noise when cranking
Turbo317
i got a squeaking noise when motor is cranking. can't really tell where it is coming from. I thought it was coming from accesory, but i pulled off the serp belt and cranked and is still there... car has a cranks but does not start by the way. just wanna know what this squeakin is.
TIA
Sounds like your crank sensor is making contact with the interupt ring. Probably why it doesn't start either! It is located at the balancer area/ front of the block.
its not the sensor, ive pulled it off and cranked it to see it was still there and it was... i do have a new im gonna through on though also.
Thanks again
