SS Machine bars
aquickv6
I know there has been some problems with the SSM bars and the frame of the car, but these bars work great. Is there another LCA on the market that will work as well with the ATR rear sway bar that will not cause any damage to the car? Again, a LCA that works as well as the SSM.
Just my $.02...
Ever since I had my forward lower control arm mounts welded and reinforced with washers (welded in), I've never had any problems with the SSM bars.
SSM, ATR bar, stock uppers, KYB shocks, no air in airbags, 12# on footbrake with combo below = 1.44 60'(!!)
Thanks for the info. Do you have a full weight car and drive on the street also? That's exactly what I am looking for is mid 1.4's.
The SSM seems to work better than anything else I have seen short of the full Wolfe setup.
Reinforce the front mounting hole (closest to the rearend), and use the factory rear hole or the instant center lower kit for the rear mount?
