stabil
jlat
hello people; I don't know if I spelled it correct but it's the gas stabilizer for storing gas powered equipment. Anyway I've never used it before and what's up with that bottle? I couldn't get it to flow and it spilled alot on the ground and the car. I've heard it works and we will see. If I use it again I'm going to transfer it to another container and put it in.
IBBY
i never had a issue with the bottle spilling. did you break the foil on both caps?
hello people; Yes I did but when doing something new you will learn things. I know one side is a measuring side but maybe because I was trying to dump the whole amount there was a problem.
IBBY
IBBY
you didn't say that first. thats why you were having an issue. btw whats IBBY
hello people; If your from the Boston area and old enough you should remember I'll Be Blasting You. IBBY
If not google Major Mudd and witness a stupid kid show that I use to watch.
IBBY
To avoid mess I use an old hockey water bottle. Keeps it from spilling and it fits right into the filler neck.
My wife got me a large syringe with a plastic tube from the vet clinic to 'inject' it in the gas tank - no spills since that stuff is expensive :D
