stage 2 block, crank, rods, and ect
straycat990
Senior Member
I have decided to sell off my stage 2 parts to help fund the purchase of a new house. The following will be sold as a package deal. I do not want to piece it out.
153 on center block
matched set of 6.200 carrillo rods w/sps rod bolts
BMS 3.59 crank turned .030/.040 ready to use, fresh out of machine shop
set of isky solid roller lifters & rev kit
BGC intake for on center stage 2 (new)
comp cam billet solid roller cam dur @ .050 232/232 lobe lift .350/.350 lobe sep 112
$3700 firm
specs on the block are as follows
bore size 4.004
lifter bores bushed
front and rear caps are cross bolt mains
one cyl has a sleeve (has been run since sleeve was installed)
No Welds or cracks
Block needs line boring. ( block came out of a road course car ...had fluctuating oil pressure last lap. number 3 and 4 main had the bearings get welded to the caps (they did not spin). The block was fine, no damage at all. I also have 2 new caps to replace the damaged ones.
David
