What kind of bearing clearance are used with a dry sump pump on a stage2 block?Are the Fel pro head gaskets good enough with a bore of 4.050 and stage2 aluminum heads?Need picture of dry sump pump location and brackets that are need to run stock water pump pulley,alternater,crank pulley power steering?
