countrybumpkin
TurboBuick.Com Known SCAMMER
- Apr 13, 2007
Looking To See How Much I Can Get For My Unfinished Project Any #'s Will Help
Stage 2 Off Center 4.010 Ready For Assy Has Ben Hard Blocked
Bms Crankshaft Balanced For Je's
6.5 Carilla Rods Resized
J&e Forged Pistons And Pins
Speed Pro Rings Custom Set
Race Bearings Rods And Mains
Bhj Damper
J&w Billet Flywheel
Comp Cam Solid Roller
Comp Cams Roller Lifters
Chapman Ported Stage 2 Heads
T&d Roller Rockers
Polished Power 6 Aluminum Valve Covers
Custom Stage 2 Intake With Fuel Rails
90 Precision T/b
Conleys Performance Custom Headers Ss
Percision 160 Injectors
Precision Gt 4276 Bb Turbo With Polished Comp Housing
Tail Waste Gate
Pt&e Turbo Saver
Transmission J&w Th 400 All Billet Parts And Full Rollerized
Ultra Bell
Steel Drum
Steel Hub
Custom Converter
Champion Gn-1 14 Bolt Heads Fully Race Ported By Champion Racing
Scorpion Roller Rockers 1.55
Arp Head Studs
Cometic Head Gaskets
Program Billet Main Caps
Billet Roller Cam Kit From Comp Cams Complete No Machine Work To Block
1987 Buick Turbo T Blue With Blue Interrior Sweet Looking Rolling Chassi Air Bags Installed Digital Dash /auto Meter Tach/a Pilar Boost Gauge Possi Rear Moser Axles/moser C Clip Aliminators/weld Roms
15*8 And 15*4 Rear Tires Are New M/t Streets Never Ran Sticker Still There
Hr Parts Lower Control Arms
No Motor Installed Or Transmision Everything Else Is There
Also Gn Finned Aluminum Rear End Cover New Looks Slick
New Front Cover Never Installed
New Egr Cyl Never Used
New Gn Full Emblem Set
All Auto Meter Liquid Filled Gauges 7 Total
Egt New Never Used
Air Bags Never Used
Power Master 200 Amp Alternator New Never Used
Toney Dequick 4 Core Aluminum Radiator
Precision Front Mount Ic New Cond 4,000 Miles
Hotchkiss Rear Suspension Packge Complete Adjustable Uppers And Lowers With New Bushings And Trailing Are Brackets New
Complete Vacuum Block With Hoses And Steel Lines Egr Cyl Valve
Msd 9 Mm Plus Wires
Theres More That I Have Forgot What Is This Package Deal Worth Pm If Pics Are Needed Thanks To Those That Reply
Bhj Damper
J&w Billet Flywheel
T&d Roller Rockers
90 Precision T/b
Tail Waste Gate
Pt&e Turbo Saver
Ultra Bell
Steel Drum
Steel Hub
Custom Converter
Arp Head Studs
Egt New Never Used
Air Bags Never Used
Msd 9 Mm Plus Wires
