SignUp Now!Originally posted by postal
Thanks for the info guys.
Man the flow numbers on stage 2 heads would turn a SBC guy green with envy! To have a bore thats close to 4" even and have those kind of flow numbers.......WOW!
There are issues that come up when you go to stage 2 heads. Alot of the turbo Buick guys dont want to mess with them. If these where heads for a SBC guys would pay a ton of money for them and jump through all the hoops. Why don't more Buick guys run stage heads.
Jason
Jason
Originally posted by chevyII
can you run a stage head on a 3.8L bore? Also anyone try stage heads with the stock stroke on the street? Ive heard theres flow isssues with the current available headers- ATR????
I wasn't sure the huge valves would clear the small bore. Im in the middle of a build. And seeing the prices for full port GN1's made me think. I thought Id read somwhere that the ATR primaries were small or to restrictive and to look for old precision pipes?
I guess it depends how deep your pockets are. Precision (not available anymore, I think), Kooks, and probably others are definitely better, but at more than twice the price. If I were a rich man...
Originally posted by Mac in SD
Well, the S2 heads come configured for a 2.02.1.60 valve combo. But most used heads have bigger valves (mine are 2.125/1.625), so I would check for 3.8 bore clearance with used heads.
Re: the ATR primaries, I'm assuming you mean headers, and the ATR's are 1 7/8, which is pretty big. The restrictive part of the ATR's is the primary from the #2 exhaust, which is a really tight bend to the collector. And the crossover pipe alignment sucks. But I guess it depends how deep your pockets are. Precision (not available anymore, I think), Kooks, and probably others are definitely better, but at more than twice the price. If I were a rich man...
Originally posted by Dusty Bradford
I just built my first set of headers for my turbo V8 project. The headers weren't that bad. Just takes some patience and don't get in a hurry. It took me about 3 weeks working in my spare time to get them and the crossover done.
The intake is another story. I have seen someone try and weld the bung to an intake with a 180 TIG and it's not anywhere near big enough for the job. The shop in town that does the intakes has a large TIG like the water cooled 375. You can do it without the water it just takes longer because of the heat.
