Stage 2 Iron on stock block???
From what I understand..with these heads you have to run a carb. style Stage 2 intake and stage 2 headers...Not sure where the seller got the "stage 2 cam" part....
heads
Stp i think he meant odd fire cam, as the valve confugraton is different in the stage heads, i have a pair of brand new [ in 1986] never been used iron heads they weight 31 lbs, alum, stage heads weight 21 lbs, my heads are bare, they have seats and guides, ill give you a heck of a deal on them, cheeep did you sell your on center motor yet,? that give away price that you had on it some one was bound to buy it, later:D
OC you have mail...Don't want to use the iron Stage heads on this offcenter...I did email you on the M&A's u used to run..cya
You'd have to run a stage 2 cam because the valves/ports go IEIEIE rather then EIIEEI.
Ahhh stupid Scott...BTW my name is Scott . Wasn't calling GNScott stupid.
