limitedv6
Stage 11 in the work's
- May 5, 2007
4.1 Stage 2 offcenter 016 block
4.045 bore
# 5 & 6 cylinder is sleeved
CP Pistons
6.300 DLS rods
BMS std/std 3.590 crank wide journal crank
CAT SFI flywheel
BHJ SFI balancer
DLS front cover with DLS oiling system (new)
Aluminum pulleys
The motor has two heli coil's in the two of the top pass head bolt holes. The block came from Conleys years ago and was dropped off a pallet so a back corner peice has been repaired. The motor at sometime broke a rod and hurt the bottom of number 5 & 6 cylinder but did NOT window the block or anything. I have ran this motor with no issues this is a good bottomend. I made sure to take pics of the spots that has had work done to it and will answer any questions that I can.
PlEASE READ EVERYTHING AND TEXT E-mail or call is the fastest way to contact me.
Email
Jmcdonald@afseal.com
Text or call
502-827-9243
I won't hold it or anything but may trade if I can sell what I trade for pretty quick.as I have another car I am buying.
NEED IT GONE ASAP
Thanks and sorry for the long post
6900 with all listed
6200 with out oiling system
4.045 bore
CP Pistons
6.300 DLS rods
CAT SFI flywheel
BHJ SFI balancer
Aluminum pulleys
Text or call
502-827-9243
NEED IT GONE ASAP
