Stage Heads On Stock Block ?
boostmaster
Will Stage 2 heads and stock intake fit on the stock 109 block. If not what modifications will be needed to make them compatable.
Let's say that you are indeed using a stage-II intake, can you use stock headers, or even Hookers for the stock head on the Stage-II heads? Thanks.
Nope, won't fit. You probably need to do a search in this forum. I believe this subject has been covered before.
