Stg 1 Heads
On the set I had the decks were considerably thicker than the 8445 castings.
I had them O ringed for 1007 gaskets, ran them into the 9,7's on my Stg#16 block with ARP head studs, no gasket problems while using a FAST (Fel-Pro)
system. Look for a #10 cast in the head below the center exhaust port, this will tell you if it's a true so called Stg1 head.
9sec.
