Stage II motor oil back??
11secGN
Where is everyone running the oil back from the turbo on there stage II motors?
Some run back to the stock location(drill a return). It is a great idea to put a return in the pan and run -10AN to it if you are building the motor now. Some of the bigger turbos it is very difficult to route the line around the housings without problems if you use the stock drain location.
Hope this helps.
