Stage II parts
Ron Tarabori
4.030 bore 153 crossbolt block. Roller cam bearings and bronze lifter bores. Nice block but bottom of middle cylinders have been caught with a rod. No pan rail damage. 3.905 bore 4X casting. Crossbolt front main. Starter corner cut off. Bronze lifter bores for .874 lifters, std cam bearings. Block has been o-ringed and is drilled between cylinders for cooling. Can have the starter corner put on for an additional $100. 3.625 BMS crank, std rods and .010 mains, LA Billet Kryptonite crank 3.580. .010 rods and std mains. 6.5 Oliver rods. A very nice set of 40+ cc heads with T & D rockers. Roller lifters with rev kit, valve covers, intake, front cover and enough stuff to put together an engine. Buy one block and crank and the parts for $3500. Both blocks and cranks and all the parts for 5500. If the package doesn't sell I'll start parting but want to give it a couple of days first. I will take odd fire crank and rods in trade. Best to call me for all the little details you will want to know. Thanks Ron 814 435 2939. Keep trying, I'm hard to get in touch with sometimes.
