Stage II timing cover, Rollmaster/ TA timing set, MSD Distributor
Mike E
Mr. Badwrench
Stage 2 timing cover with water pump and fuel pump cover plate. I just put a new seal in it. $100 shipped
TA performance 1523 (rollmaster CS7000) billet double roller timing set. $100 shipped
MSD billet distributor. Just rebuilt with brand new cap, rotor and bearings. I got rid of the modified reluctor setup and installed an MSD cam sync pickup and magnet on a new adjustable disc inside the distributor. It also has one of the polymer BOP engineering drive gears. $200 shipped.
It's new. It's been installed (some hammer marks on crank gear) but never run.
hi mike
i converted the dist i bought from you to hall effect msd it works awsome
do you still have the timing chain and bms cover
