Stage top end, Rotating kit and more
buickstage II
Hi to all from downunder,
a breif history on what i have for sale here, i built a N/A Stage motor here in Australia some time ago, with about 10 hours of run time i pulled the engine down as i reallised the amount of static compression i had for my N/A setup was nowhere near enough, unfortunately at this point i found a hairline crack in the block and after much debate i decided to move onto a World Products 454. and now im trying to part things out.
i will do my best in getting qoutes for freight and im more than happy to package items for you.
most parts were bought new, nos, or good second hand condition. as Mike booher and many others can vouch, i have spent alot
feel free to email me simon_mckeon@yahoo.com.au
All prices US
Balanced Rotating Assembly
Moldex 3.625” Wide Journal (BMS forging)(Never cut, light polish only)
Carillos 6.500 Off Center Wide Journal Rods (clearenced for cam on B.E.)
JE Dish Pistons to suit 4.015 Bore, 433 Grams, 1.193 C. Height, .927” X 2.750” Pin
Manely 0.125 x 2.750 x 0.927 pins P/N 42210
Milodon Gear Drive P/N13800
JW The Wheel 168 tooth (Zero Balanced)
BMS Hub
BHJ Decking plate
$3000
BMS Stage II Heads, approx 46cc
Jessel Rockers 1.6 Int. 1.55 Ext.
Moroso Aluminium Valve Covers P/N 68232
Stainless REV Valves 11/32”, 5.160 X 1.600” EXH & 5.160”X 2.080” INT.
Manely 4130 3/8” x 9.500” pushrods P/N 25369
$2000
RJC Pulley Kit
$250
MSD Distributor P/n 8551 (Complete)
+ spare distributor locked, no trigger
$200
X6 Second hand pistons, possibly JE
35cc Dish to suit 4.015” Bore
0.250” Deck, 1.191” C. Height, 2.750” X .926” Pin, 1/16”1/16” 3/16” Ring Grooves
X6 Second hand pistons, Wiseco?
30cc Dish to suit 4.020” Bore, (one to suit 4.023”)
1.200” C. Height 1.0, 2.0 & 3.0 Ring Grooves
X6 NOS JE pistons, trial fitted only?
2cc + Valve reliefs, to suit 4.015” Bore, 2.875” X .927”Pin,
1/16” 1/16” 3/16” Ring Grooves, 1.191” C. Height
All 3 sets $400 ono
Dominator 7” Converter N/A with transbrake (Brand NEW)
To suit PG with Turbo input spline, chev bolt pattern
Built for strip use with a tight 6500 stall, in 3000lb or less vehicle
$500ono
All prices US
BMS Hub
BHJ Decking plate
$3000
$2000
RJC Pulley Kit
$250
$200
All 3 sets $400 ono
$500ono
View attachment 165008View attachment 165009View attachment 165010View attachment 165011
Does the BHJ balancer have a trigger wheel by chance? (I know, long shot.) Should you decide to separate.
Don't really want to seperate items yet, i think my prices are fair and would make a very cheap option for someone needing a rotating kit or top end.
Thanks Simon
Got pics of the distributor and spare cap ? Condition ?
Oscar, the 5 pictures below are of the 8551 which i bought new, asthetical and functional like new. just don't have any spare springs or stops, have the box and paperwork it came with though
this s the 8554 i bought of mike booher, its locked and has no trigger, all in good condition, some wear on gear.
thanks Simon
SHADOWII, sorry it doesn't have a trigger wheel, only a reluctor ring
Interested in the crank if you seperate let me know thx
2nd in line on crank if u separate
not sure if you guys are running on or off center, but im more than happy to work out a price with freight, whats your zip code?
would those pullies fit on 3.8?
bpman1234, let me know if you interested.
Thanks Simon
sorry for the delayed reply everyone, if you email me i can reply asap as i can recieve emails on my iphone
If you decided to split the package shipping on the crank will be to 33317 plantation florida thanks
A fedex qoute for 7 day air economy is AU$542.47 (insured for U$2000)
My questions is what price is a crank in this condition worth?
and who is interested in the rest of the rotating parts?
Thanks Simon
i have a 109 almost stock block so from your 1st reply i don't think therer going to work if your sure with your answer.but i am also looking for a front mount intercooler .let me know.
