With a wet sump set up, (using the Duttweiler oil system) would only the rear return be used to feed the engine? Could I set it up with a "T" for front and rear oil feed? I am using -10 line to the rear and possibly a -6 line to the front (front hole is 1/4" rear is 3/8") By the way on the Duttweiler oil plate the front internal return line is plugged and can be used as an external return line.
What is the difference between heat treating and nitrating a crank?
Thanks,
Jeff
Thanks,
Jeff
