Can stage2 block #153 be bored out 4.040 or bigger and still be streetable?What is the true deck height on early stage2 blocks and the last stage2 block #153 casting?I have a real early stage2 block no real casting #like the ones i have seen but has #plus xxxx.What comp. cam spring does anyone recommend for the stage2 aluminum heads with duttweiler cams?Is the stock valve size for these heads 5.560?
