Stage2 roller lifters
49-blues
Can stage 2 roller lifters and rev kit be used on a non stage2 cam and GN-1 heads? I figure they should be better than what comp cams offer.
Pushrod cups will be offset differently for S2 heads vs stock style. Comp's solid rollers are bad I never had an issue with them.
109 and rev kit. I've mocked that up before and didn't have a problem. All I mocked up was the block GN1 heads and the rev kit. I can't say if the pushrod cups will be off by a few thousandths or what as I did not measure.
Thanks for all the input-I guess I will be using my stage2 roller lifters on the build and will talk with RPE to see what he recommends, anything interesting I ll post it.
