Nov 11, 2001 #1 T transguy New Member Joined May 25, 2001 Messages 38 Does anyone know the checkball locations for the stageright transbreak, On valve body side I put in the front and back one and noticed that the brake no longer worked. Any help would be great, Thanks Dave
Nov 11, 2001 #2 G GNeric Guest You have to install the front and middle ones. The rear (low control) stays out or the brake won't work..the one nearest the replacement valve.
Nov 11, 2001 #3 T transguy New Member Joined May 25, 2001 Messages 38 Thanks, the shift kit took out the middle one! Dave
Nov 12, 2001 #4 M makurtz Guest You can leave out the middle one too. Thats how your shift kit firms-up 2nd gear.
