SignUp Now!Exactly right. Never remove material from the governor weights. If you want to change the shift points by modifying the governor,put a weaker or stronger spring in the small weight. This modification will lower or raise part throttle as well as full throttle shift points. If you like your part throttle shift points,leave the governor alone. There should never be a need to modify the governor. The way to raise your full throttle shift points without affecting your part throttle shift points is to put a stronger spring in the T.V. limit valve. I use a kitchen scale and press the spring down an the scale to the same height as it would be in the valve body. Find another spring that when pressed to the same height adds 2 or 3 more ounces of pressure to the scale. This will be a good starting point to help you figure out how much spring pressure you will need.Hacksaw said:But that will throw the other shiftpoints off.
