Stageright Transbrake
DaySleeper
I'm installing a stageright transbrake on my GN and would like to know if I will be able to build boost on the transbrake.
I see you are relatively new, but posting this in 2 forums is not the norm? :confused:
You actually added more info in the Tech Section, but the answer is still YES, you must have the proper combination of parts for it to build boost.
Thanks! I'll know for sure soon enough because I'm gonna try to get it installed in the next couple of days. I got a #3 drill bit at work I'll need which is dang close to the .215 the directions call for.
I posted in here also since it was tranny specific and can't delete the other posting.
I used to launch mine at 18 on a stage right. One thing I did have to do was stop between the burnout box and starting line, engage the brake for a second and then put it back in gear to roll to the line. If I didn't, it would roll forward a little when I engaged the brake on the line.
