Some info please, I changed my cooler lines from high pressure rubber to braided, and i noticed that they are slightly smaller dia. could this increase the stall speed a little?
Thanks for your help
Any trans guru's out there with an answer to this? the rubber lines and fittings are .300 inside dia. The braided lines are .250 inside dia. Restricting the flow will that increase stall speed any at all even a little bit? Thanks Tom
momentarily restricting or shutting off converter charge does increase stall speed but this is NOT what you are doing.kenny duttweiler is the one who let that info out to the public and then freddy brown transmissions in ny used that info to make a valve body that shuts off converter charge until desired boost level is reached and then turns it back on.he even patented it but others were making it before him.im trying my hands at it as well.
