My car starts up just fine when it's cold, but if I drive it for even 5 min then shut it off then turn it back on and put into gear it wants to die on me. I can even tell a little bit when it is cold then put it in gear the car takes too long to get used to the load then finally adjusts itself to run in gear. When it gets warm it dies on me when i put it into gear and when I start it back up it idles bad for a while then back to normal after a minute of driving. I also get alot of spark knock at 15#'s boost. This all happened when I went from a 206/206 hydraulic to a 206/206 roller. Any suggestions?
Can't find vacuum leaks
double checked cam sensor installation
FP 42lbs
IAC: 20 hot
MAF: 5
BLM: 128
George
FP 42lbs
IAC: 20 hot
MAF: 5
BLM: 128
George
