Stalling issues, sometimes back fires through exhaust.
Readings are as follows:
170 - 185 degrees
O2 400-600 warm at idle
Air Fuel 07 - 08
IAC 07-12
rpm 750-800
New plugs, wires, coil pack, module, MAF O2 sensor and crank sensor. Cleaned and checked grounds at rear, and all sensor connections. Cleaned IAC. Checked cap and rotor on cam sensor, and setting. Changed ECM, no difference. Have not yet checked fuel pressure. Maybe fuel pump cutting out?
Does back firing occur in rich or lean condition? Plugs are nice tan colour. Starting happening out of the blue 4-5 days ago. Don't think it is the cam. Motor relatively new, as wiped a cam couple years back. No codes are registering.
What do I do now?
170 - 185 degrees
Air Fuel 07 - 08
IAC 07-12
rpm 750-800
What do I do now?
